Thread: Solar cover/blanket and filter question
    May 2012
    Northern Connecticut
    103
    Can you run the filter while the solar cover is on? Also do you know if you can put the safety cover on the pool during the summer, like while you are on vacation so no one gets into the pool?
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    39,280
    Re: Solar cover/blanket and filter question
    Typically you can run the filter with a solar cover on. Only exception for concern I can think of is if you have in-floor cleaning jets that shoot water up the wall which then ends up on top of the blanket.
    No reason you can not put the safety cover on whenever you like ... other than the hassle.
    May 2012
    103
    Can I leave the safety cover on for like a week in the summer, and if I do will my pool be icky when I get back?
    First Pool Ever!
    39,280
    Sure you can leave it on. The condition of your pool after the fact depends on many factors, but covering it should actually help maintain FC levels as the sun will not consume it and will prevent debris from entering the pool.
    May 2012
    103
    Thanks!
    First Pool Ever!
