Results 1 to 7 of 7
Thread: Trial and Error with SWCG settings and CYA levels
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Hi, new pool owner, pools been open a couple weeks and just turned over to me 5 days ago.
    Test Results
    FC 7.5 Was 11 couple days ago, and 14 couple days before that
    CC 0
    PH 7.8
    TA 70
    CH 140
    CYA ~38
    SALT 2900
    So i'm dialing in my SWCG. PB wanted it (from his experience) set at 55%. With my autocover being used while we aren't swimming the pool's heat and chems seem to really be staying in. I've dialed the SWCG down to 20% and as of last night i'm at 7.5.
    So My CYA is low, do i have a need to raise it to the recommended 70-80 range? I don't appear to have a problem yet of keeping FC, but again my pool is covered unless being swam in. So maybe it's open 2 hrs a day. Weekends will be different of course, as will Chlorine consumption via bather load.
    I know this is going to have to be trial and error on my part and i'm fine with that, I'm just curious if i have a need to get CYA up, given the constant "shade" my pool has.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2007
    Poughquag, NY
    217
    Re: Trial and Error with SWCG settings and CYA levels
    I was concerned about CYA levels when I put my SWG pool in as well. Mucked around for a year or two and finally realized that the SWG just works better with whatever the recommended level of CYA is. In my case, the Aquarite wants 60 to 80. When I keep the CYA levels there, everything is nice. When I tried to keep it lower, it seemed to have a lot more problems.
    I think the board consensus (plus the SWG Pool School article) is that SWGs work better with a bit more CYA than non-SWG pools.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    In your case, if the pool is covered, you could run lower CYA levels, since the water isn't exposed to UV (sunlight) that breaks down the chlorine. You could try it. Test your total chlorine level daily maybe towards the evening and see if the SWCG is maintaining the desired amount, other wise you may need to raise the CYA level.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I wonder, is there any benefit to lower CYA levels?
    18'x43' Sport Pool
    Lower CYA levels make it easier to shock the pool.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    So how often (assuming I get the SWCG dialed in) do I really need to shock the pool. My PB keeps talking about using the super chlorinate feature of the SWG. As I understand it if my chlorine doesn't ever drop I shouldn't have to shock unless I have a huge bather load one weekend or some other event.
    18'x43' Sport Pool
    Apr 2011
    Murrieta, CA
    2,360
    Correct. I've not had to shock my pool in the past year. SWCG maintains the chlorine level nicely, but have had to add some liquid chlorine after a heavy bather load.
