Thread: Maintaining Acid Level
    Feb 2012
    La Quinta, CA (near Palm Springs)
    9
    These are my current readings using the Taylor K2006 test kit:
    FC - 3.2
    CC - 0
    pH - 7.5
    TA - 80
    CH - 250
    CYA - 48
    Salt - 3500
    Water Temp - 84
    Air Temp - 100+
    See equipment specs in signature block
    I have to add 8 to 16 oz of muriatic acid every day to maintain the pH at about 7.5. It tends to go to 7.7 very quickly. The pool is 11 months old and has a PebbleTec surface and a spa spillway into the pool. I get minor scaling on the tile but brush it 2-3 times a week.
    Is this normal to have to add this amount of acid this frequently?
    14,000 gallon outdoor in-ground plaster pool (PebbleTec); Jandy 2HP 2 speed pump; Jandy AquaLink RS Power Center; Jandy Model 1400 SWG (1.25 lb/24 hr chlorine); Jandy CV580 cartridge filter (580 sq ft), 150 gpm flow rate; Zodiac 400,000 BTU gas fired heater.
    22,542
    Re: Maintaining Acid Level
    That's not out of the ordinary to have to add that much acid. You could let the TA come down a bit and see if that helps.
    30,403
    That's quite a bit for the age of your pool but the issue is you really have no choice. That you are seeing some scaling indicates the pH has been above 7.5 before so I would suggest you take it down to 7.2 and see how long it takes to get to 7.8. The waterfall is making a contribution to the pH rise as well.
    It may be helpful to lower your TA down to around 60. You must do it according to the article in Pool School.
    Regardless of how much acid it takes, I would never let your pool go above 7.8 because of the history of scaling you have experienced.
