Thread: ok to exceed Normal FC range ?
    Mar 2009
    Charlotte, NC
    539
    My recommended Normal FC range is 4-8. Is there any harm in Targeting FC 9 instead of 8, just happens to be less measuring etc. What is the harm so long as Iím below shock level?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Re: ok to exceed Normal FC range ?
    That is fine. The only negative is that you will use more chlorine in total.
    Feb 2008
    Denton, TX
    5,061
    There is more harm in lettinng a FC get too low than making it high.
