Thread: High TA and Low pH
    Aug 2009
    Lafayette Area, Indiana
    25
    High TA and Low pH
    Opened my pool last week and trying to get everything balanced.
    First test results
    FC=1
    pH=7.2
    TA=180
    CYA=20
    I added stablizer, bleach and MA and tested a couple of days later.
    New test results
    FC=5
    pH=6.8
    TA=180
    CYA=30
    So my question pertains to pH and TA. Should I add more MA to lower TA or do I need to raise my pH first and then add MA? Or something else all together?
    AG 24' Doughboy 13,500 gallons
    225 lb Sand Filter, Intex SWG
    Royal Spa Emperor II 545 gallons
    38,320
    Re: High TA and Low pH
    You need to raise your pH (aeration or borax) and then use the acid to lower both the pH and TA. Read Lowering Total Alkalinity
    Butterfly's Avatar
    South Carolina
    10,045
    First, use borax and get your pH into the 7's. Do this now.
    Forget about TA until you are completely done with opening - then follow link for lowering alkalinity that Jason posted above
    You're done SLAMing when:
