Results 1 to 7 of 7
Thread: Should I allow a dog in pool?
    both my dogs will go in the pool i did have to train them to in and out from the steps the only thing you must do is clean out your skimmer baskets (due to dog hair)
    it is fun to watch them swim i have one that will run off the dive board to catch the ball
    so i would say its fine for them to go in but watch the liner
    Feb 2008
    Flower Mound, TX
    The only issue that I have heard of regarding precautions for having dogs in the pool is if you use borates. The mods can probably shed more light on it but I think there is some evidence out there that points to borates having a certain degree of toxicity in dogs, however that may only be true if the dog drinks the water.
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    If a pet gets most of their daily drinking water from the pool and you have borates around 50 ppm then there is a likelyhood of some symptoms. If you train your pet not to drink pool water, or they simply don't drink very much from the pool, then there shouldn't be any problem.
    I have three siberian huskies and they love to swim in our pool - and we have never had any problems. They only go in and out by the steps.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    North Carolina
    One of my labs swims the other doesn't care for it. My swimmer is trained to get out by the steps. She only swims when we say it is okay and when we are with her. I use skimmer socks and clean it shortly following her swim time, it helps with the shedding in my house! LOL! She drinks from the pool after her tennis ball play time, so i try to keep additives to pool at the bare minimum.
    It is a good idea to at least show your dog how to get out safely in the event she falls in...
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    Dec 2007
    Central New York
    Buy him a bathing suit and let him go in. First few times lead him over to the stairs. He'll get the idea fast.
    You do have stairs, right?
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    Our three German Shepherds all swim in our vinyl lined pool. So do all visiting dogs. Some of the situations you'll be dealing with:
    1. Entry and exit
    Dogs normally exit a body of water at the same point they got in. Lead your dog to the steps and teach him that's the way in, then guide him back to the steps so he can get out. GSDs are smart. He'll figure this out the first day. Then, even when you toss a toy and he dives in from the side, he'll swim to the steps for another go.
    2. Dog hair
    We don't call them 'German Shedders' for nothing. No matter how well groomed your GSD may be you will have a lot of hair floating on the surface after a dog swim session. Run your pump during a session and for a couple hours after, put a skimmer sock in the basket, and check it after 30 minutes. I found the PoolSkim to be much more effective for catching and trapping dog hair than the skimmer is. What doesn't get caught will be bunched up on the bottom the next morning. It's easy to scoop out with a net.
    3. Chlorine and wet dog
    Hose him off with fresh water when he's done swimming for the day, then dry him with a dog dryer. Because GSDs have an undercoat their fur will never really dry, especially if you live in a humid climate. If you don't dry him he will eventually get moldy and you'll know it by the smell. Fungal skin infections are a Bad Thing so don't let them happen. A regular hair dryer is not powerful enough, you'll need to get a dog dryer. Blow drying a grown GSD takes about 25 minutes.
    4. Avoid bloat
    Bloat and torsion is a life threatening condition and while nobody yet really knows its cause it is thought that excessive ingestion of air plays a role. Don't allow him to bark while swimming. The combination of swimming, barking, and retrieving toys causes them to swallow air and water which may contribute to bloat. Don't feed him 1 hour before or after swimming (or any other heavy exercise).
    5. Control access
    Once your dog has been in the pool he will always want to be in the pool. Make sure you have a dog proof fence and a locking gate with a latch that he can't figure out. Really, don't underestimate the reasoning ability of your GSD. Unless a latch requires opposing thumbs to operate, he'll get it open. Drownings happen. Don't let it happen to your dog.
    Contrary to human swimmers, dogs don't pee in a pool. Their bodies don't work that way, so sanitation is not an issue. And, if friends ask to let their dogs in, you may want to require that the dogs are well groomed (brushed out first) and that the friend goes in the water with the dog. You'll be surprised how many people won't want to do that.
    Have fun. My dogs are my favourite pool toys!
    — AnnaK —
    12,000 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
