Thread: New Plaster
    May 2012
    South Florida
    36
    New Plaster
    FC 2.0
    CC 0.2
    pH 7.5
    TA 40
    CH 300
    CYA 40
    Salt 500
    Temp 89
    S. Florida Pool
    Pool is at end of 4th week for new plaster. Been Adding about 9oz acid every am to maintain pH. Many opinions at pool stores; can I bring TA and CYA up now or wait. Want to add salt next week. Thanks for the help
    IG ~14,000 Gal
    Pentair clean n clear Cartridge 100g/
    SWG Aquapure 1400
    Hayward XL Cleaner
    Premix Marbletite Freestone series
    1.5Hp 2 speed
    TF-100
    38,251
    Re: New Plaster
    Stolen quote from linen in another thread:
    It is recommended to wait 30 days before adding salt. See: pool-school/pool_plaster_start-up
    If you are interested in some deep reading on the subject, see: when-should-salt-be-added-t42215.html
    You are probably pretty close to safe to make adjustments.
    What does your pool builder recommend as they are the only ones with skin in the game regarding warranty?
    Re: New Plaster
    If I read correctly and it has already been four weeks since the plaster was applied, then yes you should go ahead and adjust the TA and CH levels to be within the normal range.
    May 2012
    South Florida
    36
    Re: New Plaster
    It will be 4 weeks in a few days. Company says ok to add salt after 28 days. I just wanted to know if I can up the TA to70. I will get some more CYA next week
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
