Thread: phoshates
    phoshates
    What causes my pool to continue to be high in phosphates even after I have used 6 liters of phosfree? I use well water, does this cause the phosphates to be high?
    Re: phoshates
    Welcome to TFP!
    Depending somewhat on your pool size, it is fairly easy to have a phosphate level high enough to require far more than 6 liters of phosfree.
    There really isn't any point in worrying about the phosphate level. My phosphate level has been in the thousands for years without any problems at all. As long as you maintain appropriate FC levels it doesn't make any difference if there are phosphates in the water or not.
    30,426
    Re: phoshates
    jep,
    As Jason said above, you will find thousands of people on this forum that never test for phosphates and never worry about them. Phosphate levels are not important to a well managed pool.
    Apr 2009
    Burlington, ON, Canada
    344
    Re: phoshates
    Are you using a sequestrant with phosphonic acid in it? I researched if this would lead to phosphates in the water and I 'think' the answer is yes, but I don't really understand chemistry. Maybe chemgeek or someone more knowledgeable than me can chime in.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: phoshates
    The thing to remember is, phosphates are algae food, as long as you have no algae it does not matter how much phosphates you have in your water.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: phoshates
    Don't sweat it. Focusing on phosphates to control algae is like getting rid of all your possessions to eliminate burglary. Just maintain the FC and you'll not only have no algae, you're water will be sanitary too.
