Results 1 to 11 of 11
Thread: Main Pump Problem
    Main Pump Problem
    My pump isn't working and tried the capacitor option, no luck.
    Any suggestion on good motor or should I replace the complete set including the housing. Please suggest.
    Also, any recommendation on who do the good job, pool store or electrician?
    I currently have 1hp, pinnacle / centurion pump. 3450rpm, p56y frame, horizontal mount.
    thanks!
    33,000 gallon (20x40), Sand, IG, Vinyl
    22,552
    Re: Main Pump Problem
    There should be a catalog number on the motor. You can use that to search for a replacement. If you'll post it here we can help you find one.
    Catalog # is 168352-04. Pac fab
    Serial no: bs10-29
    Amps 7.1 - 14.2
    Form kjm
    E44549 magnetek (right above bar code)
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Just so that I can say that I have asked this... Have you verified that there is voltage to the motor terminals when it should be running?
    22,552
    Is there other numbers on the motor? I get a 2 hp motor from those numbers.
    You mentioned the capacitor, be sure to check the centrifugal switch, too before you spend the money on a new motor.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    Any help on this issue?
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    My mental math gets about 2hp, too, from the nameplate 7.1 amps @ 220v, assuming ~746w/hp
    Volts mentioned is 230/115
    RPM 3450, 60hz
    few numbers I notice:
    174050-01
    175367-15
    part no: 35-5839
    It says 1HP , 1.25 SF
    I had hard time removing the electrical connection since it was locked with pressed plug on the motor and grounding wire had completely rusted. I had to cut it. I took it too local pool store (national spa and pool) to see if it can be repaired. I am waiting for response. I aslo checked few other stores on the motor, I was told motor can be replace for around $275-$300. Anything particular I need to watch for or ask to avoid common pitfall? Please let me know.
    Hello,
    I ended by a new one A.O. Smith USQ1102 and paid $279 for it. The old motor had rusted was not repairable. Is this a good motor and right price for it?
    22,552
    That is a good motor and the price doesn't look bad at all.
