Thread: Pentair Intelliflo VF repair
    This post is just an FYI about a problem I had with the intelliflow vf pump when starting up this season (North Carolina). It worked as expected for the first week, then the LCD panel went blank. I had bought the pump through amazon and had my electrician/handyman install it. I called pentair, and received excellent service despite the fact that, of course, it was a month out of warranty. The local pool company came out to look at it free of charge, and even though the LCD came back to life after several days, replaced the control unit under warranty. It seems there was a problem with some of the boards used in the pumps causing failures, which supposedly has been corrected with a design change. Hopefully this is true.
    So the long and short of it is there may be a defect in the circuit boards of some of these pumps, and Pentair stepped up to the plate and fixed for free it even though technically it was not under warranty. I was very impressed with the service provided by Pentair and hopefully I will not have further issues.
    Efinical
    10,000 gal AG
    Sand
    Solar heat panel
    Mideast Ohio
    22,551
    Re: Pentair Intelliflo VF repair
    Hopefully you won't have any other problems. I'm glad they stepped up and fixed it.
