Thread: Taylor salt test vs Easy touch
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    Hey everybody. I understand from reading this site that a +/- 400 result is the norm. Here's my situation:
    Easy Touch panel says 3050 ppm
    Taylor salt test shows 3800 ppm
    My water temp is 74 today
    Which is likely to be closer to correct? Trying to decide whether to add a little more salt or not
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    Re: Taylor salt test vs Easy touch
    The Taylor test is more likely to be "correct". On the other hand, it is the SWG that you need to keep happy. How old is the SWG cell? Old cells, or scaling, will often make them read lower than actual.
    Jan 2012
    West KY
    243
    The cell is new this year. Has been in service about 1 1/2 months
    Interestingly, I just checked the panel again and it now shows 3200 ppm
    TF100 Test Kit
    SpeedStir
    Aug 2011
    Northville, Mi
    312
    Seems there can be some wild fluctuations in that salt measurement from the easytouch. I've got the same equipment as you and my reading went from 3700 to 4350 back down to 3900 over the course of a few days with no changes to the water or anything else. The 3900 reading was more to my expectations (just knowing how much salt was put in and the pool volume), and when I measured it with some test strips last night, that's about what I got.
    So, for me, I'm relying on the test strips from now on.
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Jan 2012
    West KY
    243
    Thanks for the replies. I think I will rely on my Taylor salt test for "accuracy" as long as the Easy Touch sees a high enough level to be happy
    TF100 Test Kit
    SpeedStir
    Feb 2011
    Petaluma, Ca
    665
    I had an issue like this last summer, but more severe. The ic-40 was reading mid 2500 ppm +- but the Taylor test was at 3600 ppm. At that level it stopped working and I didn't want to add more salt just so the ic-40 thought it was right. After somewhat of a hassle, they gave me a new cell last fall, as of yesterday the ic-40 read 3450 ppm the Taylor test 3400 ppm, water temp 80 deg. There is supposedly some correlation between water temp and the salt reading, cooler water will read lower salt, I haven't seen that. Since the new unit was installed the readings have been within 200 ppm no matter what the water temp has been.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
