Thread: HELP with hayward 4820 de filter leak
    Mar 2012
    Eastern Long Island,New York
    82
    It seems the threads on the drain port on the bottom tank are stripped a little. Since the bottom of the filter is at least $300, I thought of a possible cheaper fix, that have some benefits. Here's my idea:
    Glue on a 1 1/2" PVC male adaptor then an 1 1/2" PVC ball valve. It would also make it easier for future maintenance.
    What do you think?
    20 X 40 Vinyl IG 28K gallons, Heat Siphon Z700HP, Hayward 4820 DE, Hayward SP3400VSP, Jandy aquapure 1400, TFTest Kit, Pool School, Pool Calculator
    South Central NJ
    3,192
    Re: hep with hayward 4820 de filter leak
    If the treads on the tank are stripped and leaking, how would putting anything other than a cap benefit?
    A cap with a rubber O-ring gasket should not leak if the O-ring presses cleanly onto the tank. If the threads won't allow that, then the lower half of the tank needs to be changed out if the threads can't be re-chased and made right.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2012
    82
    Thanks for the response. Right now with a heavy amount of teflon it is holding ok. I just thought by using the pvc cement on an 1 1/2 male adaptor then a ball valve it would eliminate any worries of a big leak when I'm not home, and still be functional and very cost effective.
    BTW I had a bad weak with this filter, when I opened the pool and power vacuumed I accidently had the multiport in backwash and not waste. My grids are packed with DE and im debating just getting a new set of grids, to allow me time to try and clean them and have them as a spare. I googled and there are so many mfg's of grids do you have any recommendations?
    Thanks so much
    Rich
