Thread: My control panel is blank
    WNY
    35
    The pump was turned on for the first time this season. The pool company just left a bill in the door with a note" no display". I went out to look and the display was on and I checked the salt level. I went to add salt and then ran a system check. After that the display just read "purifier" which I had never seen before. Then some of the letters in "purifier" started going and now nothing. I changed the battery and no display still. I have seen a few posts regarding no display but no remedies have been posted. Any ideas out there?
    Thanks.
    23000 gal. 18 x 36 IG vinyl
    Jacuzzi Magnum Force 1.5 hp. pump
    Jacuzzi CFR 100 cartridge filter
    AutoPilot Digital 220 SWG
    LaarsLite 250 gas heater
    WNY
    35
    Re: My control panel is blank
    Well after having the pump run for a while I went back out to check. Still no display. So I turned off the pump at the power switch for the 10th or so time and when I turned it back on it said "turn off pump"!. I didn't and let it be for a minute and now it is working fine. Go figure.
    Ft Lauderdale, Florida
    1,455
    check your wire harness between the two circuit boards to make sure all the wires are tucked in properly.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
