foosboy2 said:
Guys I am taking measurements, but as far as chlorine I am not even measuring anymore. I put in a gallon last time and threw in a 1lb shock a few hours ago and nothing is chaning the chlorine reading so now what.
Mitch,
I don't mean to sound harsh here...but I think it's time to be realistic.
That single statement above indicates what the problem is here. You're picking and choosing your own prescription of what to do, from a number of different sources, without a fundamental understanding of the impact of any of them.
1) "...as far as chlorine I'm not even measuring anymore."
Why not? If you're following the How To Shock Your Pool article, or the advice any number of us have given you here, then you understand that measuring is the core of what's happening. You absolutely must know how much chlorine is in your pool, so you can maintain a level of it that will attack and kill any organics in the pool. Without measuring, you're guessing, and wildly throwing chemicals in hoping for an instant fix.
2) "I put in a gallon last time..."
There's not a single set of readings in this entire thread that suggests 1 gallon of 12% pool chlorine is the right answer. This statement suggests, again, that you're just dumping chemicals in hoping for magic.
3) "...and threw in a 1 lb shock..."
Where to begin with this statement...
BF reminded us just a few posts above that "non-chlorine shock" can create a chlorine demand. If this is the same chemical that you just threw a pound in of, you're working backwards.
Nowhere in any resource you've been referred to is the recommendation given to add "shock"...nor has anyone here suggested it.
Finally, this forum and Pool School are positively littered with references to the idea that "shock" is a verb, not a noun...it's part and parcel of understanding this entire mindset.
4) "...nothing is chan[g]ing the chlorine reading..."
But the chlorine reading IS changing. Your Total Chlorine and Combined Chlorine have BOTH climbed after the addition of liquid chlorine. Both of these readings are moving in the direction you'd expect them to.
Had you read, and understood, the resources you've been referred to here, and the advice you've been given here, these two facts would have been clear to you.
Every person here wants very much to help you return this pool to a safe, attractive, enjoyable place. Not one person in this thread just randomly decided "You know what, let's mess with Mitch today!"
But BBB isn't some sort of "black art" or "magic". There is no magic bullet, Mitch. There is no single step you can take to clean this pool. Your pool has organic material in it. It must be killed, and removed. Doing so is a process. BBB is about understanding what that process is, and why it must be that way.
If you decide that you'd like to learn, and understand what's happening in your pool, why it's happening, and what steps you can take to control it, then carefully re-read this thread, and all the resources you've been given here to educate you.
If you'd prefer to be told what to do, and be given a magic cure-all that you can drop in your pool and see instant results, then you should most definitely follow the advice of one of the 3 pool stores you referenced earlier.
It won't matter which one. They'll all work equally well.
