Results 1 to 7 of 7
Thread: New guy and new pool owner
    May 2012
    Gulfport, MS
    59
    Hi all,
    My family and I just purchased a 30' Vogue Simbio AGP and are very exicited to get it up and running. I am planning on using the "BBB" method and I have the Taylor K-2006 test kit. I have read "Pool School" once and starting to read it again. Learned an awful lot so far. Look forward to getting to know other members.
    30'x54" Round Vogue Simbio AG ~21,000 gallons
    Pentair Sand Dollar SD 60 w/ Pentair Dynamo 1.5 hp Pump
    Vinyl Uni-Bead 25mil Liner
    Perfect Bottom w/cove
    Taylor K-2005 & K-2006 Test Kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: New guy and new pool owner
    Welcome to TFP!
    You're off to a great start: good test kit and reading Pool School!
    22,548
    Welcome to TFP.
    I have the same pool in the 24' version.
    May 2012
    Gulfport, MS
    59
    Thanks for the warm welcome... Quick question..Myself along with some neighbors are installing the pool this weekend. I have the ground prepped and ready to go. Should I put 12"x12" patio pavers under each vertical upright?
    I am going to use "Washed Mason's Sand" as a base for the liner....Will 2" of sand be sufficent?
    Chad
    22,548
    You need to put some type of "blocks" under the uprights and 12 x 12's are as good as any.
    2" of sand is fine. Are you using foam cove or sand cove?
    May 2012
    Gulfport, MS
    59
    Foam cove with a Perfect Bottom System.
    22,548
    Good choice.
