Results 1 to 9 of 9
Thread: New Liner
    New Liner
    Hi All,
    I just got a new liner installed. Over the weekend I had been filling it up with water. It's about an inch to the level of the skimmer now.
    I'm wondering if there's a good starting point/strategy as far as what chemicals first to put.
    No chlorine, ph at 7.5 and alkalinity at 50. No calcium (didn't change color).
    Any suggestion is appreciated.
    Jovian
    Jovian, Pool owner since 2011
    Specs: 30k Gallons, Sand Filter, IG, Vinyl, Filter: Hayward S244T, Pump: Hayward 1.5 HP SP2610X15
    22,543
    Re: New Liner
    Testing your pH and TA was a good start. As soon as you can run your pump, start it and add about 2 ppm of bleach to the pool. Then add enough CYA to get to about 40 ppm and go from there.
    Explain more about the calcium test. The sample didn't change color at all? (It remained clear) Or did it immediately turn blue?
    Re: New Liner
    Thank you. Calcium remained clear.
    To add cya can I just put chlorine pucks?
    22,543
    Re: New Liner
    It shouldn't have remained clear. When you added the R-0011L it should have turned some color. Are you sure you followed the instructions correctly? You probably should try that again.
    You can if you have plenty on hand, otherwise I'd just use granules.
    Re: New Liner
    Here my latest reading:
    FC: 0
    Cc:0
    TA:90
    CH: remained clear as soon as I added 5 drops of 0011L. One thing I don't recall is the color of 0011L last year, as this is my only second year using BBB, cause right now it's more like a brown red syrup looking. Any ideas?
    Cya:0
    I'm pouring Clorox every night but knowing the low cya, it seems useless.
    I read somewhere in this forum that there's a product to increase cya and lower ph level(don't remember where). Am I right?
    Please advise.
    Re: New Liner
    Sorry, forgot to add ph, it's close to 8.2
    30,403
    Re: New Liner
    Address the calcium issue last. You have important work to do FIRST.
    1. Lower the pH to 7.4 or so. Use muriatic acid. Do this now. Why do you think it jumped from 7.5? It shouldn't have.
    2. Purchase and add enough CYA to get to 50ppm. I suggest you only put half in for now to get to 25ppm....you'll add the rest later.
    3. Keep putting chlorox in your pool in the evening. The CYA only is useful to protect chlorine from the sun.
    I think you need to shock....what does your water look like?
    Re: New Liner
    I think I read the PH incorrectly the other day, it was more like 7.6 already. Now it's between 7.8-8.2, but closer to 8.2. I think it came up because I added about 400 oz of Baking soda, to increase TA from 50 to now 90.
    Using the pool calculator, for the cya, it says I need to get 160 oz of stabilizer. What product do I get and Where can I buy this?
    Water looks cloudier now.
    Thanks for all the help.
    22,543
    Re: New Liner
    Don't worry about anything else until you get the pH down. Use Muriatic acid for that.
    Once you get the pH down dump enough chlorine in there to get to about 3 ppm FC.
    Stabilizer is CYA, cyanuric acid, conditioner, etc. Look for 100% (or very close) cyanuric acid as the ingredients. Pool Stores will have it along with most big box stores, even Walmart sells it in the pool section.
