Thread: Intex 1600 Sand Filter
    Apr 2012
    Wantagh, NY
    5
    New here....I have been reading a lot on TFP on the Intex Pools....Great Site
    We started putting up the 18'x52" Intex Ultra Frame this past weekend. Everything looks good. Still filliing the pool up, we have very low water pressure so its taking quite awhile to fill.
    My question is about the Intex 1600 Sand Filter. We put the sand in the tank and got sand in the filter . Can we back wash to get the sand out of the lateral? Or should we just empty the sand out, clean best we can and start over?
    18 x 52 Intex Ultra Frame
    1600 Sand Filter
    Re: Intex 1600 Sand Filter
    Welcome to TFP!
    Backwashing won't do anything. Running the filter in normal filter mode will wash the sand out of the laterals and into the pool. I forget, if that filter has a rinse mode, rinse will get the sand out and wash it out the waste/backwash connection.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, RoseF
    My memory may not be great (neighbors pool, last season), but I think it has a rinse mode.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Yes, that filter has a rinse mode.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Apr 2012
    Wantagh, NY
    5
    Thank you...once the pool is full, we will try it.
    1600 Sand Filter
