Results 1 to 8 of 8
Thread: Thanks to my wife, we need a new pump..........
    Jul 2010
    Central Illinois
    40
    The pool is 18' X 54" deep with a Hayward power flo lx 1.5hp with a hayward cartridge sw110mpaks filter. I need a new pump and I'm thinking I do not need 1.5hp, but don't know for sure. Also I can buy a Hayward 18" sand filter really cheap from a friend, model S180T. I'm thinking a 1hp hayward Matrix pump or a dynamo. Would I be O.K. with a 1hp pump? Would it be an upgrade buying the sand filter? I also have a 8gal liquidator on the system? Any help and recommendations are much appreciated!!!
    18' x 54" Round AGP, Hayward pump/Cartridge Filter, 8 Gallon Liquidator, and TF-Test
    Re: Thanks to my wife, we need a new pump..........
    Yes, a 1 HP matrix or dynamo would be fine. Even better for saving money would be a two speed version of either of those pumps.
    I'm not sure which filter you currently have, "sw110mpaks" doesn't match with any of the models I am familiar with, so I'm not sure how the sand filter will compare. In general I recommend getting a filter larger than that sand filter. Larger filters can go longer between backwashings/cleanings and are generally more efficient overall.
    Jul 2010
    Central Illinois
    40
    jason that was the model number off of the housing and says Hayward Voyager
    22,550
    I can't find that model filter, but it appears to be 110 sqft. It's a bit small but should be ok for that pool. Bigger is better.
    I suggest you look at a 2-speed pump. I also wouldn't get the sand filter unless it's almost a giveaway.
    Jul 2010
    Central Illinois
    40
    Thanks Jason and Bama, I went with a 1hp matrix but now I'm thinking the filter is too small. My surface area is 254 sq/ft and my cartridge is rated for 100 sq/ft. Should I be filter shopping also??
    22,550
    That filter is a bit small for that pump and while I would suggest getting a larger one it's not an emergency. I recommend a 150 to 200 sqft filter.
    Jul 2010
    Central Illinois
    40
    Wouldn't a 18" sand filter be enough, around 1.75 sq foot
    22,550
    A 24" would be the smallest I'd suggest.
