Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Need advice on a timer ...
    FastCougar's Avatar
    Jun 2011
    Eastern Panhandle of WV
    99
    I have just (yesterday) finished filling the pool with water after I replaced the liner about a week ago. I have an 27'x52" AGP with roughly 15,500 gallons of water in it. I have a SWG that I'm going to fit into the system after I stabilize the water to my target settings for a SWG system. My hose TA is extremely high and the pool tested @ 240
    Once I knock that down to my target of 60-80, the plan is to get a timer and wire in the SWG and pump. So, I have a little time to search for the best timer for the money. I have a $200 budget and will be doing the wiring myself. That said, the SWG has a 3 wire line with no plug and has been reconfigured to 110v (came 220v, followed manufacturer's directions to convert to 110). The pool pump currently is running a 3 prong plug (large central ground plug). So obviously I need a 2 circuit timer and would like to avoid cutting my plug end off the pump. Does anyone know a timer that has a 110 receptacle AND wiring block or do I need to bite the bullet and hack up the pump plug?
    16,000 gallon 27'x52" Above Ground Pool
    Hayward XStream CC1000 Filter w/1HP Pump (hard plumbed)
    My Build Thread
    May 2012
    North of Charlotte, NC
    312
    Re: Need advice on a timer ...
    A pretty cheap / basic fix if you don't want to cut the plug end off would be to use a nipple and add a weather proof FS box out of the bottom of what ever timer you decide to go with and put a receptacle in it with an in use WP cover.
    There are a few other options but depends on room and more details of what you have and your plan.
    Any specific reason why you didn't leave it set up as 220V if you had the option ?
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    FastCougar's Avatar
    Jun 2011
    99
    Didn't keep it at 220 because the pedestal that everything will plug into (pump is already plugged into this) is 110 on a 20 amp CGFI 2 receptacle outlet.
    My Build Thread
    I had the same situation as you. I ended up getting an Intermatic T103-R timer. I have 110 going into the timer, one circuit coming out to a gfci receptacle with a weatherproof cover. My pump had a 3 prong plug so I just plugged it in. I then put a 3 prong plug on the SWG so that I could plug it in to the other outlet on the receptacle. The plug is a $2 item at most hardware stores and simple to install. It works great so far.
    15' x 30' x 52" Oval AGP; 1hp Hayward Powerflo LX Pump; Hayward Sand Filter; 4 2'x20' Sungrabber Solar Panels; Compupool CPSC36 SWG
    FastCougar's Avatar
    Jun 2011
    99
    Thanks Sturge33 ... looks like we have the same SWG to boot!
    Can you do me a huge favor and get some pictures of your setup and share them here? Thanks in advance if you do!!!
    My Build Thread
    FastCougar's Avatar
    Jun 2011
    99
    just so I have it straight in my head, your setup goes:
    Electrical Line From Home >> Pedestal with T103-R >> GFCI receptacle with cover & 2 outlets >> pump & SWG pluged in ... so the timer in essence controls all power to the area ... is this correct?
    My Build Thread
    May 2012
    312
    Quote Originally Posted by FastCougar
    Yep..that is the typical basic set up for 95% of pools with a time clock wired into it, or the time-clock can be located inside the house at the electrical panel to eliminate the expense of needing to install a weatherproof time-clock enclosure and from there run to the pedestal into a switch box (for easy shut-off locally,for backwash/strainer basket operation) then to the outlet,and plug you equipment in.
    Yes, that's it. I'll upload a picture when I get home this evening.
    FastCougar's Avatar
    Jun 2011
    99
    awesome, thank you both!
    My Build Thread
    This is the panel:
    And this is the outlet that is wired into the timer:
    If you add a plug to the Compupool, the black wire is hot, red is neutral and green is ground if you have it switched over to 110.
    FastCougar's Avatar
    Jun 2011
    99
    Thank you so much sturge33! I'll be ordering that timer tonight. Oh yeah, thanks again for the hot/neutral heads up!
    My Build Thread
    FastCougar's Avatar
    Jun 2011
    99
    Any chance I could coax a picture of inside the timer box to see the wiring?
    My Build Thread
    Sure, I will get you one tomorrow morning.
    FastCougar's Avatar
    Jun 2011
    99
    Thanks so much! Figure why reinvent the wheel since we both have the same setups and I haven't wired mine up yet.
    My Build Thread
    The terminals are labeled A, 1, 2, 3, 4. Both neutral wires go to A. Hot from line goes to 1. And hot from load goes to 2. Terminal 3 and 4 are for a 240v setup.
    FastCougar's Avatar
    Jun 2011
    99
    Thanks again ... I owe you a beer or two
    TA is dropping slowly but surely ... started at 260, currently 130. After TA is nailed and pH is at 7.4, Borates are next up on the list (need more Muriatic acid for pH offset) and then once everything tests out within my target ranges for SWG setup, the SWG will be setup. I have ordered the timer and it should be here early next week. The current pedestal has the 2 outlet weatherproof housing already, so that can be re-purposed. All I need is some conduit and the plug for the SWG wiring.
    My Build Thread
    FastCougar's Avatar
    Jun 2011
    99
    Got the box in today, had it up and running in under an hour after a short trip to Lowes ... thanks for everything!
    Water is spot on, just need to plumb in the SWG this weekend and add the salt.
    [attachment=0:2ncqit2c]2012-05-23 at 19-07-47.jpg[/attachment:2ncqit2c]
    My Build Thread
    22,545
    Looks good!
  20. Back To Top    #20
    Jul 2012
    Camden, NY
    3
    Sturge, i have a question, your pool timer controls power to your gfci outlet, when it shuts the power off to it do you have to reset your gfci? i thought when they loose power(gfci) you have to reset them everytime. could i put in a gfci breaker at my panel box and have my pool timer control power to a non-gfci outlet?
