Thread: Stenner for Muriatic Acid (Which one and feed rate?)
    Aug 2007
    Austin, TX
    343
    I am impressed with my first Stenner. Now I am in the planning stage to purchase another for my muriatic delivery. Suggestions on the pump and feed rate? If all possible I want to control the feed on the same timer as my current Stenner which is for my chlorine. The tricky part with the Stenner pumps is to figure out the feed rate based on using it at the max feed rate to reduce the noise and maximize the longevity of the pump.
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Re: Stenner for Muriatic Acid (Which one and feed rate?)
    I don't recommend trying to put both acid and chlorine on the same timer, especially if you are also trying to stick with the max feed rate as much as possible. Chlorine demand and acid demand tend to vary in unrelated ways. Chlorine demand is mostly about water temperature and bather load, while acid demand varies with TA, which is not correlated with either water temperature or bather load.
    Aug 2007
    Austin, TX
    343
    Understood. I am just trying to prevent a $300 upgrade. I currently have a dual Intermatic mechanical timers. I would have to purchase a Intermatic Three Circuit Clock P1353ME. Which might entail other expenses.
    22,551
    I agree with Jason, and wouldn't try to run the acid and chlorine pump on the same timer. Also, there's no way for us to help size your acid pump because we don't have a clue how much acid you use per unit of time.
    Quote Originally Posted by Sabot
    I just bought a cheap timer from home depot for $20 to run my chlorine. They have digital ones, but mine is mechanical and only goes in 30 minute increments. It is fine for chlorine though. What is the value of the intermatic timers?
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
