Thread: How long should I backwash for
    hawkeye's Avatar
    davenport,iowa
    118
    I usually do it for about a minute or so so.......is this long enough to flush out sand? I'm running a 22 inch sand filter with 150 lbs sand......thanks and nice to be back on boards it has been awhile hello all!
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Re: How long should I backwash for
    You should backwash until the water going through the sight glass is basically clear.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    what macgully said
    Sometimes the backwash starts out clear, then becomes cloudy/opaque before becoming clear again. I would guess my average flush is around 1.5 minutes maybe a little less. Don't forget to got to rinse and let the valve clear (you use the sight glass for this too), before going back to filter.
    Also, don't flush until your "clean pressure" goes up 25%...sand filters are actually become a little better at filtering as they get dirty.
