Thread: How to remove the pool light enclosure?????
    Jul 2011
    Mesa Arizona
    190
    I've got an older plaster pool. It was green a few months ago but I finally got it cleaned up and in good shape. Today I was swimming around and I got to messing with the pool light. I figured it was in there with springs and such so I decided to pull it out and see what holds it together. Well, it came out except at the top. I can't get the light to come completely out and when I got it partially out, a bunch of black looking stuff came out. I'm assuming it's a combination of algea and dirt.
    So now I want to get the light out so I can clean all that gunk out. Is there a screw or something that I'm missing???
    Thanks.
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    Re: How to remove the pool light enclosure?????
    There is usually a screw somewhere around the rim holding the light in.
    Jul 2011
    Mesa Arizona
    190
    Yeah, I ended up taking some swim goggles and taking a dip. I found the screw and got the light out. I cleaned what seemed like pounds of slim out of where the light goes in. Maybe that's why I have so many algea blooms. I got it all though. Even the green on the wire that goes to the light, and the slime on the tags. It's all gone. I should have done that a long time ago but I never thought the light is just kind of floating in there. I thought is was sealed in some way.
    Live and learn.
