Thread: Equipment_Upgrades ...pump&filter
    hello im new here and been doing a lot of reading of the forums....im looking to upgrading my pump and filter
    as of now im using a super star clear cartridge filter
    here the pump
    and over all picture
    so it a 40,000 pool and spa combo in ground...with pool sweep
    looking to upgrade to a SAND FILTER and pump that will work with the same situp
    looking for something inexpensive that will do the job thank you
    Re: Equipment_Upgrades ...pump&filter
    Welcome to TFP!
    What are you trying to change/improve with this upgrade?
    Can you make out the HP and SF listed on the motor nameplate?
    Do I understand correctly that your pool is 40,000 gallons?
    And finally, what region do you live in?
    I,m looking to upgrade to a sand filer and a new pump and moter
    As you can see by the picture it,s a cartridge filter
    I bought the house about 6 years age previous owner had it for 8 years and had the pool installed
    The pool is a free form pool they said it was 38 to 40 thousand gallon pool with a deep end of 10 feet deep
    Last year I had the bottom blow out of the filter and had the bottom replaced but now looking into getting a sand filter system
    Los banos California
    In CA electricity usually costs quite a bit. If that applies, you should think about getting a variable speed pump. They can save you a great deal of money in the long run by using significantly less electricity. There are several good variable speed pumps, the Pentair IntelliFlo and Hayward EcoStar are the two top models.
    For a large pool like that I recommend getting a 600+ lb sand filter. The Pentair Triton TR 140 is one of several good candidates. Sand filters are a well understood technology, so all of them are fairly similar to each other. The larger filter will allow you to go longer between backwashes and is more energy efficient.
    If that combination is too expensive for your budget, you should think seriously about keeping what you have now.
    Thank you for the information
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    If it isn't broken why fix it. You may want to swap out the pump to save money, but otherwise save your money and enjoy the pool.
