Thread: Water shooting out of Blower Pipe
    Jan 2011
    Doylestown,PA
    5
    I was trying to get my Spa ready for gas delivery and when I put the jets on, water shot out of the Blower ( which does not work and will be replaced). The pressure literally tossed the blower off of the Pipe and when it came off I saw antifreeze still in the pipe. So the first question is...Shouldn't the blower be cemented on the pipe?
    2nd question is...What caused the pressure to get so high to back flow into the blower pipe. Is there supposed to be water in there? Could it be I forgot something while opening the pool as far as cycling the water. I admit that someone helped me close last year and I'm still figuring out the ins and outs of my pool pump plumbing. The Spa is attached to the pool and it's a bit quirky directing the valves properly sine the markings are worn off.
    I do have a pool guy that comes over and I'll be calling him over for a some beers and to mark all pipes. I'm a bit concerned the blower literally shot off though...
    Also, last year when me and my pool friend closed the pool he noticed some leakage in the Jandey valves. I took them apart this Spring and he was dead on. The Directional valves are a bit worn and not totally sealed. It's not enough to cause major flow issues but they will need to be replaced before the end of summer IMO..
    Sorry for the typos...I'm on my tablet out by the pool filter..
    36k IG Plaster Carlton Pool Lake-1992, Hayward SP2615X20 Super Pump 2-HP, Hayward DE-480S, Hayward 267A Heater, Silencer Portable Spa Blower 1 Horsepower - 240 Volt,
    Polaris I80, TF-100 test kit
    Re: Water shooting out of Blower Pipe
    The blower should be friction fit, for more or less for this exact reason.
    The most likely cause is a winterizing plug, or perhaps a clogged jet, on one of the spa jets. That could force water backwards through the air pipe.
    Rebuild kits are available for Jandy valves and are fairly easy to install.
    Jan 2011
    Doylestown,PA
    5
    Thanks for the tips.
    I think it was the O rings that came with my new spa returns. I used the smallest ones and stepped it back to the larger O rings and that seemed to do the trick.
    Now I just need to buy a new Blower.
