Results 1 to 10 of 10
Thread: Trying to lower TA
    Jun 2011
    Frisco, Texas
    70
    Trying to lower TA
    I've been trying to lower my TA for the past few weeks and can't seem to get it to budge (it's always at 90). I've followed the instructions by adding MA to reduce PH to around 7.0 or 7.2 and then aerate. I'm using my SPA spillerover and a table rock water fall to aerate. Still my TA doesn't seem to reduce at all.
    Here are my results today.
    FC 5.0
    CC 0.0
    PH 7.8
    TA 90
    CH 270
    CYA 50
    Salt 3200
    I added more MA to reduce my PH to around 7.2. I've also added some more CYA to get it to 70 (will check results later next week).
    I would really like to add borates to my pool as well to around 50. But, can't seem to get my TA down. What else can I do?
    33'x21' In-ground (23,000 gal) - 8' spa raised 18" with 8 jets | Filtration Jandy DE 60 | Sanitation Aquapure 1400 SWG | Pumps Intelliflo VS+SVRS 3.0HP & Jandy 1.5HP stealth water feature pump | Heating Jandy LRZ400 | Lighting Jandy LED Spa (1)/Pool (2) | Coping Tennessee Crab Orchard & Moss Rock | Finish pebble sheen type (riversand) Tahoe Blue
    Re: Trying to lower TA
    Give it time. Every time you add acid, the TA level is coming down. However, it can take a couple of cycles of add acid, raise PH, and repeat before it moves enough to be obviously different in the test results.
    Jun 2011
    Frisco, Texas
    70
    I was assuming that by doing this for 3 weeks or so, that my TA would reduce. So it's normal for this to happen? (I need to work on my patience that is for sure). Everything else with the pool is great - the water is crystal clear.
    Alright, three weeks is "some time". Your TA should have gone down by now.
    Can you give me a list of all of the pool chemicals you have been using in the last three weeks?
    Jun 2011
    Frisco, Texas
    70
    The only thing that has been added to the pool in the past 3 weeks is the following:
    CYA (just today) after the test result
    Salt (2 bags)
    MA
    I've also been adjusting the % on salt cell (between 30% to 40%)
    That is it.
    Hum, the only other possibility I can think of is fresh plaster in the last less than a year. Fresh plaster will raise PH, TA, and CH levels rapidly for the first 4 weeks or so, and more slowly for up to a year.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I take it that you have not added borates to your water? 'Cause that would have an effect like you are seeing.
    Jun 2011
    Frisco, Texas
    70
    The pool was just built - water put in mid March. I guess I will continue to wait and see if the TA comes down at all. What is the downside to me adding the borates now? Just curious.
    I have not added any borates yet.
    It is a bit more difficult to lower TA with borates in the water. Given your situation I figure you might as well go ahead and add borates now.
    Sep 2011
    Mount Belvieu, TX (20 miles east of Houston)
    7
    I was able to raise my pH quickly by running my spa blower while spilling over.. Seems like each cycle of adding acid could be done in about 8 hrs. But as everything, YYMV.
    Good luck
    20K IG Diamondbrite, Intelliflo VS, Intellitouch i7+3, Blue Diamond Robot, Goldline T15 SWG, Borates, MiniMax, SAM/SAL, Cold Beer.
