Thread: Common Practice for IG Pool Piping ?
    May 2012
    North of Charlotte, NC
    312
    Just curious if its been common practice or even known practice for piping coming into pump pad areas from underground to/from skimmers, returns, dedicated lines to be flex pipe underground all the way to each connection on the pool or just stubbed out from underground and up to my pump station ? I plan on re-piping my pump/filter station and was just curious of what I'm in for once/if I need to dig down a bit ?
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    Re: Common Practice for IG Pool Piping ?
    Some builders use flex pipe for the entire run. It isn't all that common, but it is done now and then.
    May 2012
    312
    Thanks Jason, I guess I'll find out eventually soon enough when I reconfigure everything....
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    The flex pipe is more expensive than standard sch40 pipe but it saves on labor as it is available in 100' rolls. Somebody once mentioned that it is more susceptible to bugs/animals chewing threw it also. I have purchased alot of fittings throught http://www.flexpvc.com for alot less than the home/hardware stores.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
