Thread: Jandy Pro Series VS FloPro 2HP Variable-Speed Pool Pump?
    Apr 2012
    Prince George, VA
    33
    I am thinking of getting this pump instead of the Jandy Flo Pro 1.0hp 2 speed with timer....the cost difference is only $200 since the controller that comes with the
    VS FloPro 2HP Variable-Speed Pool Pump will replace the need for the digital intermatic timer.....or am I missing something?
    Barrier Reef Pacific1-Pacific color 37'9" X 14'1" fiberglass IG ~ 17,500 gallons, FHPM1.0-2 Jandy FloPro pump, Jandy Aquapure 1400 SWG, Waterco Multicyclone 16 pre filter, Jandy CV580 filter, 3 PAL-2000 RU LED lights, 1 skimmer, 2 main drains, 3 returns, 2" rigid pvc suction and return plumbing, BBB method, TF100 Kit
    Re: Jandy Pro Series VS FloPro 2HP Variable-Speed Pool Pump?
    It depends on your setup. The variable speed pump isn't setup to switch any external devices. So, if you have a SWG or heater you lose the ability to turn the SWG/heater off when the pump is off. If that isn't an issue for you then sure go for it.
    Apr 2012
    Prince George, VA
    33
    Thanks Jason, I figured it was too good to be true!!
    how has this pump worked out for you?
    maybe I am unlucky or maybe there are long term issues with these pumps. The first one failed within 4 weeks. Pump just stopped working. I got a brand new replacement via warranty and one of their warranty repair centers professionally install the 2nd - second pump failed after 6 weeks - same symptoms/issues. Jandy has no explanation on this and I am in process of getting a 3rd via warranty.
    25K gal plaster IG pool/spa - Aqua Pure SWG - Jandy RS8 with OneTouch and iAqualink - 1.5HP Jandy Variable Speed ePump - Pentair 3 HP Spa Jet - Polaris 280 with booster - Pentair Cartridge Filter - 400K BTU MiniMax Heater
