Results 1 to 10 of 10
Thread: Wanting to mount tv, rec and speakers on back porch....
    Ok I have cable running right under my eave down my back porch so I think I can splice that cable to make another outlet where I want to mount a TV. TV will be an old 25" crt that I dont care about if it goes out but it will be protected by porch.
    I bought a cheap receiver and 4 outdoor speakers from best buy that I plan out getting mounted this week....only problem is finding a cabinet that I mount to brick to hold my receiver..have anyone seen something like that this? just a 2 shelf or 3 shelf with a door that can be hard mounted to the back brick of my house?
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    Re: Wanting to mount tv, rec and speakers on back porch....
    Quote Originally Posted by 4x4tx
    Check out this site. I just searched for "TV& VCR wall Bracket"
    http://www.stacksandstacks.com/audio-vi ... ll-mounts/
    As long as you mount to a solid surface you are ok.
    I have seen them at Home Depot in the Electrical dept near the antenna stuff.
    Hope this helps you.
    Iggy
    Here is another
    http://www.flatpanelmountsonline.com/as ... 001_57909#
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    Thanks I got the TV mount..now I just need a wall shelf or component shelf.
    Mar 2007
    Morris, IL
    477
    I will be interested in knowing whether you get the 27" CRT TV mounted to exterior brick like that without pulling the bricks off the wall. Good luck.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Guest
    we put our old 27" sony out last year and this winter she took a **** and died. we upgraded to this http://www.backyardstuff.com/Games%20&% ... 0Specs.htm
    and its the BESSSSSTT tv we have ever had, it was expensive and i was talked it to it my the entire family. but im really glad i did. skip the little crt. this thing i can spray with my hose or let it get rained on and its still fine. I LOVE IT. i reccommend this. BTW. BOSE ALL THE WAY FOR OUTDOOR SPEAKERS.
    Mar 2007
    Morris, IL
    477
    That looks nice.
    steve
    Jan 2008
    Burbank, IL
    109
    Personally, I go outside to get away from the @#$%$$ TV, but you can mount about anything you want on a brick wall all you need is proper anchors.
    Wilbar 12 x 17 Buttress Free AG (~4400 Gal?)
    Hayward 225 sq ft cartridge filter
    1/2 HP Pentair Whisperflo
    Liquidator chlorine feeder
    Pool Rover Jr.
    BBB - it's the way to go
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I have a friend who did the same thing with an old tv and it's been outside for almost 2 years with no problem. They just put a cover over it when not in use. And if it goes out, for a couple hundred bucks, they can replace it. At that rate, you could buy over 25 tv's before you spend as much as the lcd RT suggested.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Guest
    Quote Originally Posted by SeanB
    we love it though. i will never, ever, spend that much on a a tv again. i said to the family if its broken you can live with out. i was going to just get another CRT. then DW and D k (kids) came and said we want this or else (not sure what the or else was) so i blew my money i had saved up to go on vacation this year on it. LOL. but i hate to say, its worth it. plus since im an avid DIY'r the cost was offset by me and my oldest installing it (spent 3 weeks). it was fun and the quailty time before he moved out was worth 50x's more IMO.
    i love to put on CMT and have the sound piped through the speakers in the back yard. my neighbors think im nuts, but who cares. :P
    Mar 2007
    Morris, IL
    477
    Quote Originally Posted by mnormington
    I agree with the whole going outside to get away from the TV. I rarely watch it inside, there is just too much life to be lived without needing to be entertained 24/7. But, I would say that as far as putting anything you want on a brick wall, I would answer that with the proper methods, yes you can, leaving the anchorments out of it though. If you drill in three anchors into brick, and chunk a 27" CRT on top of it, in my opinion, you are going to do something bad to the wall.
    If you used Lag type anchors, that expand as you put a lag bolt in them, I would imagine that it would hold, but would the weight of the TV not pull the brick? I would not be surprised if it did at least. I have never tried it, but I would then again never try it. If I were to try it I would probably get something made which would both bolt to the wall and have vertical legs for supports. Knowing a welder is probably the best thing in the world...
    steve
