Thread: Uncovered to clear water with rust stain on the bottom. ACK!
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Hi all. Here's hoping someone can help us out with this problem. We shut down last fall to clear, clean water and opened today with clear, clean water, about 3 leaves and a rust stain about the size of a small egg on the bottom. A plug had fallen out of one of our barrels we use to put under the cover and must have been on the bottom all winter We tried to rub it off with the brush on the end of the pole to no avail.
    Currently water temp is @ 70...too cold for this gal to jump on in and try to remove it by hand!
    We have added no chemicals at all, haven't even taken a reading yet as we are filling right now.
    Anyone of our experts out there have an idea as to what we could use to remove the stain? It will make me bonkers to look at that all summer.
    Thanks in advance.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    Re: Uncovered to clear water with rust stain on the bottom.
    For a rust stain, take some vitamin C tablets, crush them up in a sock, & put them on the stain. If it's an iron stain, it should disappear. Actually, one tablet would probably do it, not crushed up. Hold it on the stain with your toes, or something & it should immediately lift it. I was experimenting with them last summer on my liner that had horrible stains over the years. My sons 20 something friends were writing things on the pool liner wall. It lifted them that quickly. I did the Citric acid treatment this spring on opening & now all the metal stains are completely gone.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Thanks. I had forgotten about the vitamin C tabs. I'll give 'em a try.
