Results 1 to 7 of 7
Thread: How am I looking right now?
    Jul 2011
    Mesa Arizona
    190
    I've been working on my pool for weeks now. Got the green out, the water is clear, my home made solar heaters are working perfectly and my water seems stable.
    Here are my morning test results.
    FC=3
    CC=3
    PH=7.5
    TA=110
    CH=450
    CYA=55-60
    Water temp=87
    How am I looking so far?
    I have a solar cover and I also built some home made solar heaters and they are working beyond my expectations. It's supposed to be in the low 100's here in Mesa Az. for the next week or so and I'm thinking I won't need to use the cover or the heaters this week unless I need to cool off the water. 86 feels perfect to me. I can cool it down a little by running the heaters at night. I'm pretty happy with things so far but I'd like your opinions.
    Thanks. This site is a lifesaver.
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    30,426
    Re: How am I looking right now?
    Good numbers but could use a couple of fine tuning tweaks.
    I suggest you keep your FC 4-6ppm and you will have a crystal clear pool all summer. 3ppm is not a deal breaker but it lower than the FC/CYA chart suggests.
    With your CH being up around the top end of "OK", it would be just a little safer to run your pH around 7.2 with 7.5 as a top end. That should eliminate any possibility of calcium scale.
    Jul 2011
    Mesa Arizona
    190
    Yeah, I realize I'm a little high on the CH and also the CYA so the last few days I've backwashed to get as much of the water out as I could and replaced with new. My CYA last week was almost 90 so I've lowered that as well as lowered the CH from 500 down to 450.
    The biggest problem I have right now is the water out of my hose has 200 CH so it's a little tough to lower the CH down much unless I dump the entire pool and I'm not prepared to do that yet.
    I do get some scaling so I'm not sure what to do about that.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Is your CC= to 3
    Or is your total chlorine= to 3
    30,426
    Jul 2011
    Mesa Arizona
    190
    [quote:c260e3au]it would be just a little safer to run your pH around 7.2 with 7.5 as a top end. That should eliminate any possibility of calcium scale.
    [/quote:c260e3au]
    DUH!. That didn't sink in until now. lol. But I also want to lower the CH and the only way to do that is dump a BUNCH of water. I might do that soon but it's looking like it will be November before I do that.
    Jul 2011
    Mesa Arizona
    190
    Quote Originally Posted by Leebo
    Is your CC= to 3
    Sorry, I guess I should have said zero. It didn't register so I'm in good shape on that part.
