Thread: How chlorine to get to level (ie how much to run SWG)
    Aug 2011
    Northville, Mi
    312
    I know it's mostly "play around with it until it's good", but I like to have a "refined" target, if you will, for things.
    So, doing some reading, I think to get to 3.0 ppm of free chlorine I think I would need .4 lbs of chlorine. This is based on 16000*8.34 (lbs/gallon of water) = 133,440 pounds water and if I multiply that by .000003 (3 ppm), I get .4, or 6.4 ounces.
    Does that all sound right or am I way off?
    Because, if that's the case, my SWG tells me how much chlorine it's supposed to produce and I have my target. The IC40 says running full tilt it will produce 1.4 lbs of chlorine in 24 hours. So, if I ran my pump for 7 hours at 100%, that would give me my target.
    Do those numbers sound rational?
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Re: How chlorine to get to level (ie how much to run SWG)
    You are doing your math right, but solving the wrong problem. When adjusting a SWG, you aren't trying to raise the FC level from zero to the target level, rather you are trying to replace the chlorine lost to bathers and sunlight. That amount varies with the weather, the number of swimmers, and so on, and can not be calculated in advance.
    Aug 2011
    Northville, Mi
    312
    Well I'm doing something right!
    Thanks - it never occurred to me that I was solving the wrong problem.
    However, that sort of segues to a companion question - when is the best time to measure the chlorine? So far two afternoon readings were 0 and a morning reading was 1.
    30,432
    The FC will be the lowest in your pool usually around late afternoon or after a heavy bather load. Check it then to make sure you have not gone too low but also check it at other times occasionally to see how uniform it stays in a 24 hour period.
    Jun 2011
    Long Beach, CA
    2,790
    It is usually best to bump up the chlorine level to your target level with bleach when the FC gets too low. This way you will get your FC up quickly and will not have to rely on the SWG to raise your FC.
    Jul 2011
    Limerick, PA
    28
    Just to give you some comparison information. I have an IC-40 & a 20K gal pool. During July and August last year (pool startup late June) I was able to maintain 3-5 ppm on the 60% setting, running from 8 am -8 pm. My pool gets sun all day and kids swam most everyday. The 60% setting was probobly higher than it needed to be because I was not measuring CYA accurately. I got the test kit here and will be better able to track that better. With that said, that same setting covered the swings (rain, clouds and such) pretty well. If I knew a rainy period was coming and the kids would be out of the pool, I'd super chlorinate just to give it a boost. Had to do that during the hurricane that came up the eastern seaboard last September. I keep bleach handy to shock when needed but will probobly be able to run it less this year, at a propper CYA level (60-70).
    17x39 Rectangular, 20,000 Gal, Plaster, Pentair Easy Touch Automation and Remote
    Pentair WhisperFlow 2 hp pump with Pentair Clean & Clear Cartridge Filter
    Pentair Master Temp Gas Heater, Pentair IntelliChlor IC-40, Pentair Kreepy Krauly Legend II Cleaner
    ..and one frog that thinks the pool is his.
