Results 1 to 8 of 8
Thread: sudden increase in salt ppm
    Aug 2011
    Northville, Mi
    312
    I've got an ET4 and an IC40. Yesterday I added a wireless control to the system. My salt ppm has been around 3800 (went higher after some evaporation, then I replaced it, it was down to 3750). As of last night, it was reading at 3750 on the remote. It rained a little last night and this morning. This morning, the pump wouldn't pull prime for about a half hour (until I heard it) and took care of it. Now when I check the salt via the remote, it's reading 4350ppm!!
    Now, I'm kinda freaking out here but I haven't read it at the outdoor panel yet. Assuming it's the same, what in the world would make the salt PPM jump be 15% overnight with no loss of water??
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Re: sudden increase in salt ppm
    Did you recently heat the water?
    Support the site
    Aug 2011
    Northville, Mi
    312
    Yes. It was heated yesterday and actually the heater is on right now as I'm reading it. Will that make a difference??
    Hotter water can result in higher salt readings if the unit does not compensate for the temperature difference.
    Support the site
    The new reading with warmer water is going to be more accurate.
    Aug 2011
    Northville, Mi
    312
    Hmmm...Well that's not good.
    I think the problem is the reading anyway.
    Via math I calculated the initial amount in would be around 3600-3700 and the store measured it at 3800, same as the system.
    I've only pumped out about 1,200 gallons and pumped in maybe 600, so it's not been a huge turn over in water. I'll have to keep a close eye on this...
    Thanks guys
    22,551
    You should invest in a salt test kit. You can use either strips or a drop test. It's good to have one as a backup.
    Aug 2011
    Northville, Mi
    312
    In case anyone was interested, I ran across this post (http://www.troublefreepool.com/updat...9.html#p226647) in some other reading which is a great piece of information. According to that, the salt reading varies 200ppm per 5 degrees water change away from 77 degrees (higher readings for higher temps, lower readings for lower temps). I don't know how linear that curve is (ie, is it 40 ppm per degree?) but it's a great piece of info for me and makes sense with the previous temperature comments.
