Thread: pool sand base
    pool sand base
    What should the measurement be from the top of the sand base to top of where uni-bead liner overlaps in a 27'X52" Aboveground pool? Thanks!
    - Brandon.
    27,300 gallon in-ground Gunite pool
    1.95hp AC Smith pump
    150 gpm Hayward cartridge filter
    3 Volkswagens and a 73 Plymouth.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: pool sand base
    2-3 inch sand base is typical and is measured from the bottom of the lower pool wall tracks (i.e. if you are using pavers under your vertical supports, from the top of the pavers).
    Re: pool sand base
    So it should only measure 49 to 50 inches?
    - Brandon.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: pool sand base
    Yes, that is common if it is a 52" wall, though it you will still need to build a sand cove (or use foam coves) out a the wall.
