Thread: Water behind liner
    Apr 2012
    Detroit, Mi
    10
    Water behind liner
    Hi all, I am close to pool ownership, closing on the new house in a few weeks. I spoke with the neighbor this week and he mentioned the pool has had the liner replaced in years past because of water behind the liner. Apparently there is a lot of ground water in the area and I am pondering about a sump pump to keep water away,
    Any thoughts or recommendations.
    Just getting started and learning a lot...
    Pacific Pool Laremont 20' x 40' approximately 28,000 Gallons
    Installed our own liner from InTheSwim, 270 measurements or so.
    Equipment: ( not sponsored by Jandy, we tried to avoid compatibility issues by buying from same vendor... stop laughing!)
    Jandy Pro Series VS FloPro 2HP Variable-Speed Pool Pump
    Jandy 1.5Hp for backup
    Jandy SFTM Top Mount 83GPM Sand Filter with ZeoBest Sand Alternative
    Jandy AquaPure 1400 Salt Water Chlorinator
    Jandy LXi250NN Heater
    Jandy iAquaLink control system
    Re: Water behind liner
    It really depends on the soil conditions and typical depth of the water table. In the great majority of cases, simply keeping the pool full during the part of the year when the water table is high takes care of it. If you do have particularly bad high water table issues, having well points with sump pumps can be a large help (it often requires more than one). But running into situations that actually require that is unusual.
    Apr 2012
    Detroit, Mi
    10
    Well, I'm debating about just pumping all the water out and seeing how quick the water comes back. We have to replace the liner anyway. It has steel walls with duct tape on the seems, so there is no real way to stop the water from coming in.
    Apr 2012
    Detroit, Mi
    10
    Just a follow up to this.... has anyone installed a garden hose permanently under the liner? I was thinking about running a garden hose to the deepest point of the pool and going out the pool wall up to the outside of the cement and leaving it about 2 feet above the ground near the fence so I could always attach a pump to it if need be. I'm worried that it may cause damage to the liner but I'm not worried about it showing.
    This would allow me to install the liner, have a plan B and then address sump pumps down the road if the water issue becomes a major problem.
    Nov 2011
    Moberly,MO
    1,010
    Water weight will flatten the garden hose to where you wont be able to suck water through it. Best choice is well points
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Apr 2012
    Detroit, Mi
    10
    Just FYI, the garden hose did the trick... I bought some vinyl hose from Lowes and ran it under the cement behind the liner half way down. I have to run the pump after every rainfall but much cheaper option than digging up the yard and installing sump pumps.
    Only downfall is some of the backfill gravel got behind the liner when installing, so the liner might not last as long as I like.
