Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: trying my hand at tiki
    i told my buddy "i could do that no problem!", and he called my bluff. so he came home with a 12" wide piece of wood and hucked it at me and grinned. deep breath on my side and then i got to work. i drew it on with a pencil both freehand and by using some cereal box paper after i sketched the design i liked. so here i am asking for approval, criticism, remarks, slander, dirty gestures, degredation, or whatever you have for me (with the exception of itchy crotch)(lol).
    the start.
    gettin goin.
    a bit more.
    and as of tonight.
    here's a better "3d" pic.
    thanks for looking!
    Still holding on to the grass so I wont fall off the planet!!
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Re: trying my hand at tiki
    Very cool. Looks a whole lot better than what I would probably end up with if I tried to do that.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    Very cool. Looks great! Wish I was that talented
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    thanks guys.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    I like that!! Way slicker than i could do, to be sure.
    I can't, however, help but post this now...
    [youtube:2rp955bj]A6rVIB8eoYs[/youtube:2rp955bj]
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    i got some more done on it today. now that i got it sanded and ready, im gonna get it cleaned up and put a coat of light stain on it then paint it up and weather proof it so i can post it out in the backyard.
    this pic should give a perspective of the size, 27" tall x 11 1/4" wide x 3/4' " thick.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Cool! Do you have a router? If you changed the bit depth ever so often you might be able to replicate the texture you get by hand carving....and depending on where you place it, it may be far enough away nobody can tell it wasn't all handcarved.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    no router. i hand carved it with a 5 piece carving set from harbour frieght and then hand sanded it a bit to smooth out the rough spots. i want to keep the texture of the doing it by hand for the more "realistic" look. it doesnt have the depth to it, but i will improve on that with next one im starting. the next one will also have horns on top so it may take longer to draw up a fitting design.
    Nice job, man. I do a lot of woodworking myself, and have never tried handcarving. I did a piece similar to yours, although not tiki. Drew out a design on a slab of oak, and used the carbide cutting bit on my Dremel. Produces roughly the same result, but with a ton of little lines. Stained out nicely, though.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    thanks. i wish i could of used oak, but the pine worked out decently. ill try different wood each time to find the best for hand carving. did you use a light or dark stain?
    Feb 2012
    Phoenix, AZ
    728
    Very cool!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Take a torch first and burn the wood some before you stain it. Gives the wood a different texture.
    Looks good!
    Quote Originally Posted by Leebo
    Looks good!
    good idea! ill go try that. that will eliminate my need for staining.
    and here we go! now for paint.
    Neat!
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Quote Originally Posted by E-ROC
    I always seem to steer towards Golden Oak. Not too dark, not too light.
    Digging the burned look....looks great!
    Kansas City, MO
    1.5 HP single speed
    the burning is really cool in person. does anyone have suggestions on what to use for a final protective coating that will hold up to so cal summers without yellowing or peeling/flaking/cooking off in direct sunlight?
    Jul 2011
    Eastern Ohio
    7,092
    http://www.amazon.com/gp/product/B0016Z ... ull-site=1
    I've heard good things about this, but never have used it.
    painting done! just need to clearcoat it now.
    and this is the blank to start the next one.
  20. Back To Top    #20
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    I like that!
    -Gordon
