Thread: DIG-220 display
    DIG-220 display
    I have an Auto Pilot DIG-220. When the pumps turns on, the display works for a short time the goes out. I believe the system is operating, just not the display. Any ideas?
    Ft Lauderdale, Florida
    1,455
    Re: DIG-220 display
    Not sure why the display would not come on. With newer systems, the display will go to a "walking dot", where it will show just a scrolling dot on the display. Is this what you're seeing? If so, when you press any button, the normal display will come back up.
    On older systems, if the display goes bad, but the unit is still operating, try this. With the system on, disconnect the tri-sensor cable and see if the warning light comes on. If it does, then the unit is operating with just the display being bad. If no warning lights, its possible that your control board is bad.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
