Thread: Diving Board Crack
    IkeRay's Avatar
    Houston, Tx
    154
    Diving Board Crack
    my diving board has a small crack in it. its not so much a crack-crack, but the fiberglass has a fold mark in it, ill post pics so you can see what i mean. anyways, is it repairable or do i have to replace the entire board? ive bounced on it, and the crack hasnt seemed to spread, i felt if a 200 lb guy could jump on it and nothing happen then in case a 30-50 lb kid jumped on it, it wont break on them.
    30,000gal In-ground Gunite Pool DE filter
    Polaris 380 APC
    BBB method all the way - Newb, like to absorb info and chatter, but take the experts' advise
    i would say that its time to replace the board
    i am always afraid that a board will break(although i have never seen it happen)
    do you take it in for the winter and is there a fulcrum under it?
    IkeRay's Avatar
    Houston, Tx
    154
    nope, have never moved it, and its never really been used to dive in, just got the pool to blue up. yes that is a fulcrum under it, it is about 8-10" off the ground, maybe even a foot.
    Polaris 380 APC
    WNY
    35
    I just got the bad news my board has some hairline cracks in it. The pool guy pointed them out to me. I would never have seen them. They just look like scratches. He won't put the board on that way but I am welcome to do it myself. He doesn't want the liability. So I'll be getting a new board. I wouldn't use yours if I were you.
    23000 gal. 18 x 36 IG vinyl
    Jacuzzi Magnum Force 1.5 hp. pump
    Jacuzzi CFR 100 cartridge filter
    AutoPilot Digital 220 SWG
    LaarsLite 250 gas heater
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    I think the strength is mostly in the wood core -- but with a crack, who knows what condition the core is in.... if a little water gets in there, it'll rot out quickly.
    You should be able to replace the board and keep the mount...
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
