Results 1 to 9 of 9
Thread: NEW HEATER
    May 2012
    Howell N.J.
    5
    NEW HEATER
    Wow I just opened the pool and the heater was leaking. I removed the side panel and discovered it's all rusted out. Can anyone recomend a quality brand heater for around $1,500? or what would be the best choice if I had to spend more? What is the best BTU for 25,000 gal?
    pool-20x42
    2hp hayward pump
    300#sand filter
    350,000 btu hayward heater
    chlorine
    mariane
    16 x 28 AG doughboy vinyl pool with deep end, ~11900 gals. media master 150# sand filter using zeosand, 1.4 sq ft filter area, 1 hp, 10 amp doughboy power pak pump. in sunny but fickle detroit michigan.
    Aug 2009
    SW Wisconsin
    518
    Re: NEW HEATER
    Well, for the BEST I'd say at least 250,000 btu.....with that said...I have a pool that is 25,600 gallons and my heater is the Hayward H200 (200,000 btu) and it heats it just fine.
    I don't think you'll find much for $1500, unless you are going used..
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Re: NEW HEATER
    Most people feel that they want the largest heater they can afford (and is available). 400,000 BTU is common, though more than $1500. Of course, another 250,000 BTU heater will work fine, it just won't heat up the water as quickly.
    All of the major brands are reasonably good. 250K heaters start right around $1500 (for just the heater).
    May 2012
    Howell N.J.
    5
    Re: NEW HEATER
    I narrowed it to a jandy legacy 250 btu $1,520 or hayward universal H 250,000 btu $1,749 I heard the hayward was loud though. Do you think the jandy lxi 250 @ $1,890 is worth the extra money?
    mariane
    Aug 2009
    SW Wisconsin
    518
    Re: NEW HEATER
    Loud??? Nothing loud about a heater...you can hear it "kick in" when it fires up..but that's it. It makes no other noise. If your pump is near your heater, you'll only hear your pump.
    May 2012
    Howell N.J.
    5
    Re: NEW HEATER
    I didn't get the loud part either, it was just a review I read. So jandy or hayward?
    mariane
    Aug 2009
    SW Wisconsin
    518
    Re: NEW HEATER
    Sounds like a plan to me. Either one will work well.
    Dec 2009
    Central Massachusetts
    2,690
    Re: NEW HEATER
    I have a Hayward 400k low nox. Works great. Pretty quiet too.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: NEW HEATER
    If the heater has a blower motor for exhaust, they can be noisy. Rheem makes their heaters with NO blower motor. Great heater.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
