Thread: Big time newbie here and im IN OVER MY HEAD
    I would like to start by saying thank you in advance and sorry for my ignorance to pools
    well here we go i bought this house and it has about a 30,000 gallon inground pool one main drain one skimmer 3 jets one jet on the side of the pool same side as the filter and the other 2 on the other side
    well one i did not winterize my pool what a mess i got all that cleaned up and all water is crystal clear but not theres alittle bit of dirt sitting on the bottom no big deal right ill vacuum it
    boy was i wrong i took all the proper steps and hooked my vacuum up to the skimmer i was told to set the filter to waste so i did i start to vacuum and its going ok and then i look at the one jet thats on the same side as the filter and the dirt im picking up from the deep end is shoothing out that jet into the other end of the pool and its not just alittle dirt it was flowing pretty good
    ill tell you what pools are great but Edit: Butterfly i cant win with this sucker please help again sorry for my ignorance,my spelling and my run on sentance
    Bobby
    20 x 40 28 mil liner inground with walk in steps. ecopump 2 speed 1.5 hp pump, 500 lb Hayward sandfilter with Zeo, Dig-220 with C-48 cell, Aquabot Xpress, Hayward LED, two waterway mains and two waterway widemouth skimmers
    22,551
    Re: Big time newbie here and im IN OVER MY HEAD
    Welcome to TFP.
    I assume you have a sand filter.
    If you put the multiport in waste mode an the returns are blowing dirt back into the pool, that means the spider gasket a leaking. It's a pretty easy fix. Take the make and model of your filter to the pool store and they'll be able to find you one.
    When you get that fixed start reading pool school and learn how to take care of your pool.
