Thread: The Simple Pleasures of Pool Ownership
    Mar 2008
    Wake Forest, NC
    128
    Share your simple pleasure.
    The moment when the aroma hits you from your perfectly balanced water. Just a hint of chlorine smell that assures you it is doing its job perfectly.
    This was brought on by my last addition of corrective action to my new fill water after liner replacement. After a very hard 48 hours of work(day job). I added the last of the chemicals and I caught that wonderful smell. Am I tooting my own horn? Maybe just a little.
    7days from This vvvvvvvv You can see here how I bleached my liner before I found you guys! Thanks!!!
    To this. Yes I have to vacuum up that little bit of dirt.
    All with enough test for 2 PH tests and 1 TA tests. Yes it was fresh fill but it is laden with iron TA was 50 or so CYA 0 PH off the charts. A Gallon of MA 2.5 Gallons of 12.5% CL and 6 pounds of BS and 7lbs of CYA and I am good to go!!! Woo Hoo
    Time for some TF-100 refills Dave!
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
    30,403
    Re: The Simple Pleasures of Pool Ownership
    Wow! Nice looking pool and nice water...Did you replace the liner yourself?
    music to my ears.
    Mar 2008
    Wake Forest, NC
    128
    I wish I had!!! I watched and learned. SO SIMPLE!!!! My builder, his 10 year old and a 14 year old did it. Can't find your number PM it if you could. If you are available today, I would love to come by and refill
