Results 1 to 9 of 9
Thread: In floor cleaning systems
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    For those of you that have in floor cleaning systems in you pool, my question is, how often do you use it and are you happy with the results.
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Mesa, AZ
    16
    In-floor cleaning is a huge variable. IMO, the best systems are GREAT. The rest are not worth the hassle. I think I am very lucky to have what I feel is one of the best and possibly the best there is. I use it every day. It works wonderfully. So far the 1st 4 years with the system have been perfect. I generally take the heads out about once a year just to check them out. I picked up several spare heads for less than $20 each in tha last year, but I've never had to do anything to any of the heads so far, so I save my spares for the future.
    A friend of mine has a Shasta pool from the 80's. You couldn't pay me to have that system in my pool. The heads are terrible contraptions, they're complicated mechanical items that jam, get stuck, wear out and break into pieces when you try to remove them. Replacements cost about $80 each, when you can find them.
    Chris W
    My Pool: 14K gal IG, Pebblesheen, Pentair 420 Cart Filter, Autopilot Digital SWCG, Paramount PV3 In-floor cleaning. UltraPure Ozone
    My Spa: 2007 Down East Windsor SE, Spa-Pilot SWCG :)
    My Kit: PS-234 w/salt test, Refills from Taylor and TFkits
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    Re: In floor cleaning systems
    Quote Originally Posted by meatloaf
    Thanks
    My pool was finished in January 2008 and I have the Paramount PV3 infloor system.
    The good part is that they have no metal spring like others have.
    With a salt pool this is always a possible problem.
    The pressure pushed the heads up and a small weight pulls them down.
    They automatically rotate direction each time they pop up.
    I have 6 zones in my pool for the infloor system. The controller turns on each zone one at a time.
    The basic principle is to push debre to the deep end and the bottom drains.
    Here is the link to Paramount System here in Phoenix.
    http://www.paramountpoolproducts.com/
    Iggy
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    So how often do you use them?
    iggy's Avatar
    Jan 2008
    175
    Whenever my pump is running I use them. I have the 5 return lines on and the infloor on together.
    This way I have a lot of water circulating.
    At this time of the year I filter about 4 hrs a day. I really don't need to but I want to keep my chlorine up with my salt system. This is enough time to maintain 3 PPM of FC
    How do you like your Tightwatt self adjusting pool timer? Was it worth the money?
    Iggy
    Jul 2007
    Sahuarita, AZ
    278
    In my <1 year old pool (and I think in pretty much all modern in-floor systems) the cleaners are constantly in use. In normal pool circulation mode, all water return is done through the in-floor cleaners. There is a actuator near the pad that is driven by water flow that constantly cycles through the 6 zones.
    In my system I have a variable speed pump so for most of the day its running at a very low flow just to turn over water. At this speed even though water is returning through the floor cleaning jets it's not very powerful and the zone actuator moves very slowly. So for 1.5 hours in the morning and 1.5 hours in the evening my controller turns up the RPM's on the pump to give a powerful cleaning water jet from the floor cleaners.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    The timer works just fine and seems to save $$$. Automatically adjusting throughout the year.
    Central Florida
    84
    Also have the Paramount system. Another great feature of the pop up systems is heating the water from the bottom.
    18k free form IG w/spa (4 jets), Paramount in floor cleaning system, Starite system 3 filter, Jandy 2hp ePump, Sta-Rite SR400LP Maxi-therm propane heater, Jandy aquapure/apurem 1400 SWCG, Jandy automation PS4 w/PDA, IntelliBrite 120v 5-G LED pool & spa lights, 2" piping and (3)4x12 (5)4x10 Fafco Sunsaver Solar Panels.
    iggy's Avatar
    Jan 2008
    175
    I decided to continue using my present timeclock and change it myself every few weeks. It is very easy and only takes a second. I guess if you are away then it may work for you or you just don't want to mess with it at all.
    I am one of those hands on guys. I like messing with my stuff. LOL
    Thanks 8)
    Iggy
