Thread: CYA test
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    CYA test
    Hi. I'm new to the forum and this is my first post. I have the TF-100 test kit and the label came off my CYA mixing bottle. As I understand it, the label is to be used as a guide for adding the correct amount of pool water and R-0013. I don't remember exactly where the label goes. Close to the top I think, but I'm not sure. Is there an exact ml amount of water and R-0013 that I can use for this test instead?
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CYA test
    Welcome to tfp, schertzy82
    Half the bottle pool water the other half R-0013. The lower label edge marking the how much pool water to put in was exactly in the middle of the wide part of the bottle, and the top of the label where you added the R-0013 was at the top of the wide part of the bottle.
    38,301
    Re: CYA test
    It is a 50/50 mix of pool water and reagent.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Re: CYA test
    Great, thanks! 50/50 sounds easy enough.
    Intex SWG
    30,421
    Re: CYA test
    schertzy82,
    I sent you a PM...check for "1 new message" in the upper left corner of the page.
    SoCalGary's Avatar
    Mar 2010
    Orange County, CA
    9
    Re: CYA test
    The label came off of my bottle as well. I've been using 15ml of pool water and 15ml of R-0013.
    17K Gal. IG Vinyl - 1.5 HP Pentair WhisperFlo Pump - Pentair SMBW 4048 DE Filter - Solar Heating - TF-100 Test Kit
    Pool School - The Pool Calculator - How to Shock Your Pool - Help Support This Great Site!
