Thread: Can't keep Chlorine up
    May 2012
    Taylors, South Carolina
    3
    FC -.5
    CC - Can't test
    pH - 7.2
    TA - 70
    CH - Can't test
    CYA - 50
    Borates - no borates
    After opening the pool last week I can't keep the FC up. I shocked(using bleach) last night using the pool calculator's suggestions.
    The water looked very clear this morning(It was only a little cloudy before) but the FC barely registers at .5
    The CYA is at the top of the recommended level.
    Should I try to lower CYA?? Any suggestions?
    24,000 gal
    Sand
    IG
    No size of pump or flow rate
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Can't keep Chlorine up
    Quote Originally Posted by donnyk1
    FC -.5
    CC - Can't test
    pH - 7.2
    TA - 70
    CH - Can't test
    CYA - 50
    More Chlorine!!!
    Seriously though, the bleach you're putting in is probably correct, but remember that chlorine is consumable. That is, if there are organics in your pool, the chlorine you're putting in is literally getting used up in minutes.
    Reread "Shocking Your Pool" in Pool School (upper right hand corner of every page), and remember that "shocking" is a process that could take some time.
    What kind of test kit are you using?
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, what ski said^^^
    Pool School, the PoolCalculator.com and a good test kit are your new best friends!
    Post back here with any questions. Someone will be around to help.
    Welcome to the forum
    You're done SLAMing when:
    May 2012
    3
    I am using the HTH 6 way kit mentioned as an alternative. (budget won't allow the others yet)
    I will keep shocking.
    24,000 gal
    Sand
    IG
    May 2012
    3
    Thanks guys,
    Shocked one more time and things are looking great. Still wished I would have paid a little more for the better test kit.
    Maybe next time.
    24,000 gal
    Sand
    IG
