Thread: Planning on adding a Stenner pump injection system
    May 2008
    Seattle area
    17
    I'm the defected guy, so if there's something you want to know feel free to ask.
    I'm also planning on adding a Stenner pump injection system. Based on your experience and my pool size (below), would you think I'll need the 45MPH10 (0-10 gal/day) size pump?
    I'd like to put it on a separate timer so that, during the normal pool circulation cycle, I could, if I choose to, run the injection pump at a higher rate for a shorter time period. Are there any downsides to that approach?
    32,000 gal. IG plaster (circa 1967); 24" dia sand filter; Jandy Lite 2 (250,000 BTU)
    1 hp circ. pump (Single speed, 53 gpm); 3/4 hp booster pump (Polaris 380)
    1 bottom drain, 1 skimmer, 2 return lines from circ pump, 1 return from booster pump, all 1-1/2" PVC plumbing
    22,551
    Re: Planning on adding a Stenner pump injection system
    The 10 gpd should be fine. There's nothing wrong with running it like you plan to.
