Results 1 to 10 of 10
Thread: pool water smells like paint after painting
    Hi to all;
    Pool was expoxy over epoxy painted about 4 weeks ago and filled about 5 days later due to fear of popping. The water now smells like paint. The local pool store (Leslies) had no solution. Chemical balance is correct according to them.
    Any help would be appreciated.
    Gary R
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: pool water smells like paint after painting
    Hi, welcome to TFP! Could you please post your test results? Usually our definition of correctly balanced differs from their version.
    Love TFP? Become a
    TFP Supporter!
    Many thanks for your response!!
    ph=7.4
    FC=5
    TAC=5
    TA=120
    CYA=30
    CH=260
    I can put my nose to the coping that was also painted and it smells of paint along with the water.
    Thanks for any help!
    Jul 2009
    Houston, Texas
    9,377
    You can try using the shock process to see if that gets rid of the paint smell. The test results look ok.
    Love TFP? Become a
    TFP Supporter!
    Thank you!
    We'll give it a try over the weekend with a couple lbs for our 20K pool.
    Regards,
    Gary R
    As an alternative just wondering if there are any deodorizers that might be effective.
    Gary R
    30,403
    Hi, Gary,
    I think time is probably going to be your best friend. Just like in your house, new paint gives off a noticeable smell for a period of time. If your water is clear and you maintain that chemistry (your numbers look good, almost perfect) I think that smell will fade over the next few days and slowly get fainter.
    Shocking may, in fact help, but I believe time will be your best ally.
    Hi Dave;
    Thanks, I suspect you are right!
    Regards,
    Gary R.
    Jun 2007
    New Jersey
    653
    We had an unlined steel pool for 55 years and we painted it at least every two years due to rust spots (Koppers Type S chlorinated rubber special steel pool paint--nasty stuff). I think the recommendation was seven days drying before fill (we never waited that long). One year the weather really tricked us and rain slammed us about four hours after we finished the last coat. My brother and I said "..... it" and decided to just fill it since the paint was getting soaked anyway. It really smelled, but we stuck it out and by the time it warmed up from the 55F fill, the smell was almost gone. That was about 2-3 weeks. After a month, it was totally gone.
    The smelly part of paint is the volatiles; they go away.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Hi Durk;
    Thanks for adding you info. Added some Leslie's Fresh and Clear this a.m., seemed a little less odor later today. It will be warmer this week in our area so maybe everything will be OK.
    Thanks to all for responding!
