Thread: Can I remove my light niche for cleaning?
    plucky71's Avatar
    Apr 2010
    Michigan
    116
    I can see algae inside my light niche's. I'm wondering if I can remove them for cleaning. The light power unit is super vision international series 250H. I think it is considered fiber optic lighting. The niche is about the same size as a return fitting. It has a clear plastic lens with two small holes in the lens. Can I remove the lens to clean inside?
    Outdoor fiberglass inground 15,000 gallons, Clean & Clear Plus 420ft. sq. filter, 1 h.p. WhisperFlo pump, New water cycler automatic chlorinater(not using), 1996 pool, TF-100 test kit.
    Ft Lauderdale, Florida
    1,455
    Re: Can I remove my light niche for cleaning?
    It "Should" be installed with a glued fitting or watertite fitting/gasket, otherwise it would leak. Most installers will leave enough slack on the light source end so you can pull the light fixure above water to inspect it. From there, you'd have to take a closer look to see if it is capable of disassembly.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    plucky71's Avatar
    Apr 2010
    Michigan
    116
    Thanks, I don't think I'm loosing any water so it should not be a problem. It almost looks like the lens is screwed into a normal return fitting. I think I can see threads through the lens. It looks like I would need a special two pronged tool to twist out the fitting, but I don't think there is any reason to mess with it at this time.
    1,455
    Yes, it should be a standard Hayward SP-1022 wall fitting that the fiberoptic light is threaded into. That part of your light can be removed from the wall fitting, and as I said, there should be enough slack back at the light source, to pull the light to deck level for servicing.
