Results 1 to 9 of 9
Thread: Boric Acid question.
    So, my TA is a little high, not to much I'd like it lower but its not to the point where I need to mess with it, and PH is honestly perfect. At this point I'm just trying to get my water crystal clear and silky. So going to start fussing with the borates and see what I can do. I know that if you add Borax you have to add 31.45% muriatic acid to compensate for the pH increase. That is all fine and good, but if I used Boric Acid I wouldn't have to add any muriatic acid at all? Is that understanding correct?
    If so where can I get Boric Acid cheap? I need 7 and a half gallons. -- Or is a lot cheaper just to use the Muriatic Acid and Borax even though you risk the pH changing.
    30,000 Gallon, Above Ground, Vinyl, DE Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Boric Acid question.
    Quote Originally Posted by Helltech
    How high? It is really hard to adjust once borates are in the pool. I can be done but it is more difficult. Borates are a ph buffer similar in effect to TA.
    I got mine at dudadiesel.com It made sense to me to do it this way since the cost was close.
    My TA is at 108 right now.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Well that's not bad starting point for a non-swg pool.
    Yeah that's what I thought so I didn't want to bother trying to lower it and lower it too much on accident or change anything else since everything is better than it has been in many years. So I figure the only way to get it crystal clear, since all my levels are good, is to start using borates, I just wanted to go with the simplest route.
    EDIT - So 10 pounds of Boric Acid is 55 dollars?
    I have seen far better prices than that. The Chemistry Store and Duda Diesel both have good prices.
    Duda Diesel was were I looked, but I I guess i was looking at the food grade version, whoops :P
    Thank you.
    EDIT - So do I want powder or granular?
    It doesn't matter, both will dissolve plenty fast enough.
    Thanks so much. You guys are a big help
