Thread: Use beaded liner strips as overlap strips
    Mar 2012
    NC
    138
    Is there any reason why I cant use the beaded liner casing as the strips that cover the overlap liner on the pool. It seems like the same concept, and I can just take a straight razor and cut the bead receiver off of the existing strips. Sorry to sound so cheap guys, but I tend to try to use the stuff I have around the house instead of just buying new. Any reason why this would not work?
    33' Seaspray Aegean II - 6' Deep End
    28K Gallons
    2" Hard Pipe Plumbing
    Hayward S244T 300 lb. Sand Filter
    1 HP - 2 speed - Powerflo Matrix Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Use beaded liner strips as overlap strips
    Should work as long as it fits and holds the liner tight in the top rail gap.
