All,
I have had very little time to work on my pool this week and it has been raining non stop.
I have been running my pump for about 4 days 24 hrs with the SWG on 70% to ensure that any alge will not come back and I would have to start all over again with shock etc.
Last night I FINALLY got to go out to test levels and program my pump and SWG to run 12 hrs instead of 24. (Start of process to meter down pump time to cloudy water then increase to clear water)
My tests were as follows:
FC-OFF THE CHART (Dark Pink) in TF100 basic test kit.
Ph 7.3
CYA 60
Salt 3200 ppm ( will be adjusting to 3600)
Will my FC level drop quickly or should I shut it off for the weekend as i am going out of state?
Am I screwed?
After this weekend I will be able to focus much more on the testing and balancing of the pool.
My hope is to find the right pump run time and then adjust my SWG to make my FC 4-5 per recommendations.
Suggestions?
Ph 7.3
CYA 60
Am I screwed?
Suggestions?
