Thread: Chlorine level?
    Mar 2012
    Columbus, Ohio
    16
    Chlorine level?
    Why does my test kit say 1-3 is the ideal range but TFP says 3-7 is ideal?
    24' above ground, 2008 Esther Williams, 13,500 gallon, 200# sand filter, 1.5hp pump, bottom drains.
    22,550
    Re: Chlorine level?
    Your test kit doesn't take your CYA level into account at all.
    Mar 2012
    Columbus, Ohio
    16
    Re: Chlorine level?
    But if the test only reads up to 5, how do I check for 7 or 10?
    30,421
    Re: Chlorine level?
    There is a different test to test levels up to 50 or more ppm. It is called an FAS/DPD (just DPD wont do it) test and it is really what you need to manage your pool successfully.
    Mar 2012
    Columbus, Ohio
    16
    Re: Chlorine level?
    OK I see where it says that in the TF-100 Test Kit description. Thanks.
